Aarfmann
Jul 24, 2017Aspirant
Nighthawk M1 mobile router not connecting to Xbox live
Received a new router from Telstra and Xbox live connects, but doesn't allow an internet connection. Have followed steps as suggested by Xbox re DNS settings help with no luck. Any more suggestions fr...
ArodiD
Nov 14, 2017NETGEAR Expert
Hi Aarfmann,
How are you connecting your Xbox one to the MR1100? Is it via WiFi or Ethernet? I have no issues with PS4 connecting to internet via M1.
Kind Regards,
ArodiD
- BungarraNov 15, 2017Aspirant
Connected by wi-fi..... there has to be a simple solution for this ... I just don't get it that Telstra & netgear sell incompatible stuff...
- MicWNov 15, 2017Luminary
Can you provide any information , like the error xbox is giving and the ip configuration and gateway it is using? I've tested my M1 with my nephews xbox and no issue, didn't have to configure anything out of the ordinary. The only issue you may have is if you are behind a double NAT setup by your ISP, then you can still get out, but no one would be bale to connect back to you if you try running a server
- AarfmannDec 27, 2017AspirantSays my DNS server can’t resolve Xbox live server names. I have tried all of the Xbox help suggestions.
