AndyR71
Feb 05, 2018Tutor
Nighthawk m1 (MR1100) extending range of wifi
I know the Nighthawk m1 is a mobile hotspot but I would like to leave it centred in the house with ethernet to my AppleTV. Problem is the range is not as great as the Telstra salesperson led me to be...
michaelkenward
Feb 06, 2018Guru - Experienced User
- AndyR71Feb 06, 2018Tutor
Yep thanks. Have been looking into these but just wondering if the MiMo antenna idea would solve the wifi range as well as boost the 4G signal strength? I have a landline (ADSL) connection also at the house that the kids use so an extender would need to be smart enough to be able to pick which wifi network to join. Any particular model with the lowest price?
