AndyR71
Feb 23, 2018Tutor
Nighthawk M1 MR1100 external antenna setup
I've just connected a Panorama 3G 4G 4GX MiMo Antenna to my Nighthawk M1 MR1100 and just wondering if I need to go into the settings and tell it to use (look for) the external antenna now? I had a lo...
KarmusDK
May 08, 2018Apprentice
Remember to plug it into a wall adapter as soon as you connect external antennas. It uses a lot of power and will drain the battery completely in a few hours of heavy usage.
