AndyR71
Feb 22, 2018Tutor
Nighthawk M1 MR1100 external antenna setup
I've just connected a Panorama 3G 4G 4GX MiMo Antenna to my Nighthawk M1 MR1100 and just wondering if I need to go into the settings and tell it to use (look for) the external antenna now? I had a lo...
Richard_J
May 10, 2018Tutor
Do you connect the Nighthawk M1 MR1100 antenna directly to the M1 hotspot?
- JasonNMay 15, 2018NETGEAR Employee Retired
Hi Richard_J,
Please refer to the link below and let me know if that helps fix your issue. :]
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Nighthawk-m1-Antennas/td-p/1495222
- Jason N
