Mexoh1To7k
Sep 13, 2018Apprentice
Nighthawk M1 (MR1100) firmware update
Hi,
I've got an unlocked Nighthawk M1 (MR1100) V1.0 from Telstra. Since I'm using it in another country I'm unable to have the firmware updated and it's currently running a very ancient version...
W1lliam
Sep 13, 2018Virtuoso
You can check from here https://kb.netgear.com/000059132/How-do-I-update-firmware-on-my-Telstra-Nighthawk-M1-Mobile-Router
Mexoh1To7k
It's not valid for my firmware's version as the file upload is not available.
- W1lliamSep 13, 2018Virtuoso
oh, yes, firmware upload is enabled after NTG9X50C_1.25.01.00, mine was on same version as you and tried for several weeks to upgrade the firmware via "Check for Updates" button, one day it works for no reason. You might want to keep trying for a period of time
- Mexoh1To7kSep 13, 2018Apprentice
But did you do it from Telstra's network?
no, the upgrade was done from the other country with local telecom vendor as my M1 is unlocked.
