Mexoh1To7k
Sep 13, 2018Apprentice
Nighthawk M1 (MR1100) firmware update
Hi,
I've got an unlocked Nighthawk M1 (MR1100) V1.0 from Telstra. Since I'm using it in another country I'm unable to have the firmware updated and it's currently running a very ancient version...
Mexoh1To7k
Jan 21, 2019Apprentice
If you experience difficulties in getting the firmware updated because you have an old version that doesn't have the manual update procedure, you should simply keep trying over and over and it will eventually work.
Otherwise you may have to contact Netgear's support.
Merodz
Jan 21, 2019Aspirant
Thanks!
