Jacobguest2016's avatar
Jan 22, 2019
Nighthawk M1 (MR1100) MR1100 MYMEDIA upload file fail
 MR1100’s MYMEDIA cannot update file to SD SIM on latest firmware NTG9X50C_12.04.02.00.
After I start to update file, the process would been queued. But the session would hold and then no response
i also try to use the apps upload file, but it seems that no response after I press the upload button
Does anyone have the same problem?
  • Generally media managment is rubbish. There is a new firmware, check that first.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Jacobguest2016
    Welcome to NETGEAR Community!
    - May we please know the SD card file system format used? Capacity?
    - Is it the same behavior when you download a file?
    - What is the model number of your device?
    Blanca
    Community Team
    • Blanca_O's avatar
      Blanca_O
      Hi Jacobguest2016
      This has been brought up already to engineers. I will get back to you guys for any updates.
      Blanca
      Community Team
  • I have the same problem too. The file stucked at queue and no respond
