ynateil's avatar
ynateil
nighthawk m1 MR1100 OOREDOO only works when plugged in without a battery
The router would only turn on when its plugged in into an outlet without a battery. When I plug it in with a battery, the led will start flashing blue and red light and the screen will have a low battery with charging sign and a clock under it and doesnt start at all. It will only start once the battery is removed and plugged in. I cant seem to get the battery to charge and once i unplug and try to start it, it doesnt reposnd at all.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi ynateil
    Welcome to NETGEAR Community!
    I suggest that you contact OOREDOO to do a hardware check and if device needs replacement.
    Blanca
    Community Team
    • ynateil's avatar
      ynateil
      There’s nothing wrong with the hardware and the device is fine. The only issue is the battery, I literally had this device for 1 year and the battery just became corrupt. It won’t start up at all with my battery, unlike with my friends battery. It worked perfectly fine and was charging. So I’m really confused now how can a battery become corrupt like that within 1 year.
