RoXerS
Jan 26, 2019Follower
Nighthawk M1 MR1100 trouble connecting Xbox 360 S to internet/Xbox Live
Hello-
I live in a rural area and currently, the best option for internet for gaming/streaming has been through AT&T mobile hotspot, Nighthawk MR1100. Everything is working great on all my devi...
RMinNJ
Jan 27, 2019Luminary
Did you try moving the 360s next to the mr1100 temporarily to see if it works...That would tell you if its the wireless signal.
It does sound like something is blocking the 360...ie UpNp on the 1100 but you say the xbox one works fine through it.
