kevinc2's avatar
kevinc2
Nighthawk M1 MR1100
   Battery on my Nighthawk M1 MR1100 appears to be swelling purchased from Telstra in australia     What do i need to do? thanks
  • TeeJay74's avatar
    Jan 13, 2019
    Safety first, immediately stop using that battery. Put it to safe container and dispose faulty battery properly. Then you should get new one from seller.
