KarmusDK
Apr 11, 2018Apprentice
Nighthawk M1 MyMedia support
Hello.
I have tried to open MyMedia with several memory cards formatted as both NTFS and FAT32 of these brands:
THN-M302R0640EA - Toshiba Exceria 64 GB microSDXC
THN-M203K2560EA - Toshiba M203 256 GB microSDXC
SDCAC/16GB - Kingston Action Camera 16GB microSDHC
Only the last one worked. So my question is, does the device even support the SDXC-protocol and cards over 32GB in size?
Error message:
To use MyMedia, please ensure a compatible micro SD drive or USB is inserted to your router. Only NTFS, HFS+, HFS, FAT32 and FAT16 formatted media is supported.
Device SKU:
MR1110-100EUS
- MAGADEGuide
I got the same probleme but i have a very old firmware so, what is your firmware to compare?
Perhaps it is updated in a newest firmware.
- KarmusDKApprentice
Firmware version: NTG9X50C_12.02.07.00
Btw, my SKU is MR1100-100EUS. The above has a 1-digit too much in the first part of it.
- MAGADEGuide
ok so you have a very new firrmware so probably not linked to a firmware version.
Perhaps you are in the truth, it is a issue with the SD capacity or king of speed
