KarmusDK
Apr 11, 2018Apprentice
Nighthawk M1 MyMedia support
Hello. I have tried to open MyMedia with several memory cards formatted as both NTFS and FAT32 of these brands: THN-M302R0640EA - Toshiba Exceria 64 GB microSDXC THN-M203K2560EA - Toshiba M203 256...
MAGADE
Apr 11, 2018Guide
ok so you have a very new firrmware so probably not linked to a firmware version.
Perhaps you are in the truth, it is a issue with the SD capacity or king of speed
KarmusDK
I found a SanDisk Ultra 32GB microSDHC - possibly SDSQUAR-032G-GN6MA but can't confirm - in a drawer at my dad's, and it also works. It's even quite new, because it has an A1 (application class 1) speed rating, so I am more convinced now than ever, that it is because of incompability with microSDXC.
- MAGADEApr 11, 2018Guide
for now, we have to test it with an SDHC more than 32Go like 64 or 128Go.
We will be fixed.
For information, the user manual said use sd up to 128 Go so we have to make test with SDHC 128Go. If it work that mean to option, first SDXC is incompatible or seconde option, issue with firmware and probably a fix in a future firmware.
Perhaps a NETGEAR member's team could give the good information.
- KarmusDKApr 16, 2018Apprentice
I found a way to utilize a 400GB SanDisk Ultra MicroSDXC-card (SDSQUAR-400G-GN6MA) in the router by using an old TakeMS MicroSD card reader (TMS-CR-TFL1R) I located in the same drawer as mentioned before, which is supported by the inbuilt USB drivers. As long as the card is formatted correctly, it should work. Tested with NTFS.
