KarmusDK
Apr 11, 2018Apprentice
Nighthawk M1 MyMedia support
Hello. I have tried to open MyMedia with several memory cards formatted as both NTFS and FAT32 of these brands: THN-M302R0640EA - Toshiba Exceria 64 GB microSDXC THN-M203K2560EA - Toshiba M203 256...
MAGADE
Apr 11, 2018Guide
For information, the user manual said use sd up to 128 Go so we have to make test with SDHC 128Go. If it work that mean to option, first SDXC is incompatible or seconde option, issue with firmware and probably a fix in a future firmware.
Perhaps a NETGEAR member's team could give the good information.
KarmusDK
Apr 16, 2018Apprentice
I found a way to utilize a 400GB SanDisk Ultra MicroSDXC-card (SDSQUAR-400G-GN6MA) in the router by using an old TakeMS MicroSD card reader (TMS-CR-TFL1R) I located in the same drawer as mentioned before, which is supported by the inbuilt USB drivers. As long as the card is formatted correctly, it should work. Tested with NTFS.
