KarmusDK
Apr 11, 2018Apprentice
Nighthawk M1 MyMedia support
Hello. I have tried to open MyMedia with several memory cards formatted as both NTFS and FAT32 of these brands: THN-M302R0640EA - Toshiba Exceria 64 GB microSDXC THN-M203K2560EA - Toshiba M203 256...
JasonN
Apr 17, 2018NETGEAR Employee Retired
Hi MAGADE,
It's fine to make a mistake sometimes. haha
I'm glad that you confirmed for us that it does work in the other formats! :]
Hi KarmusDK,
Please let us know if these formats work for you as well. :]
- Jason N
KarmusDK
Apr 20, 2018Apprentice
Hi.
The TakeMS reader is really some cheap **bleep**, that can easily fall apart. I also had problems with reading the card on Android, but after twisting it a little bit in the socket, I had a better strike of successes. I tried the 400GB card in another USB card reader (DeLock 91648), and it works better.
- JasonNApr 20, 2018NETGEAR Employee Retired
Hi KarmusDK,
Thank you for your response. I'm glad you have it working now. :]
- Jason N
