KarmusDK
Apr 11, 2018Apprentice
Nighthawk M1 MyMedia support
Hello. I have tried to open MyMedia with several memory cards formatted as both NTFS and FAT32 of these brands: THN-M302R0640EA - Toshiba Exceria 64 GB microSDXC THN-M203K2560EA - Toshiba M203 256...
KarmusDK
Apr 20, 2018Apprentice
Hi.
The TakeMS reader is really some cheap **bleep**, that can easily fall apart. I also had problems with reading the card on Android, but after twisting it a little bit in the socket, I had a better strike of successes. I tried the 400GB card in another USB card reader (DeLock 91648), and it works better.
JasonN
Apr 20, 2018NETGEAR Employee Retired
Hi KarmusDK,
Thank you for your response. I'm glad you have it working now. :]
- Jason N
