Ourhouse75706
Mar 13, 2018Aspirant
Nighthawk M1 No Wifi
My M1 is showing that the wifi is enabled but it does not broadcast to any devices. I have factory reset it and nothing changes. What else is there to do?
UK-based
Mar 14, 2018Luminary
The M1 is designed primarily as a battery-powered mobile hotspot, although some of us are successfully using it as a static 24/7 household router. So the default factory settings aim to minimise the battery drain. For example, the WiFi will sleep after a period of time, probably requiring the Power button to be tapped once to wake it up again. Also, I think the WiFi range is set to "Short". So those are two things to check/change in the Settings > Setup > Wireless section of the browser-based interface. I'm using my M1 without a battery so I've disabled the "WiFi Standby" and have set the WiFi range to "Long". The range is still rather limited but that's to be expected in a relatively small mobile hotspot. If needs be, you can extend its range using Ethernet-connected access points.
I can't think of any other reason why your WiFi devices aren't seeing the M1. If no one else comes up with any solutions, I'd contact your supplier.
