carleast01
Jul 27, 2018Tutor
Nighthawk M1 Optus speed slow
I purchased the Nighthawk M1 outright to use with an Optus sim rather than Telstra which is who it's sold by. However, I'm unable to get the speeds that I'm seeing with the same sim via my Samsung S...
- Aug 08, 2018
carleast01 if you bought the Telstra Nighthawk M1 (MR1100-1TLAUS) then it does not support all the Optus radio bands. Specifically it does not support TDD B40 which Optus use for the Carrier Aggregation. If you really wanted to use an Optus SIM - then my suggestions would be to buy the Optus AirCard 800S which is a CAT11 device (CAT9 out of the box but with a firmware upgrade it is CAT11) and that does Carrier Aggregation with B40, B28, B3 and B7 - all the bands used by Optus LTE 4G currently.
Thanks.
Gary
JSchnee21
Jul 31, 2018Virtuoso
Here in the USA, at least, nothing holds a candle to the S9. With LAA on AT&T it approaches 500-600Mbit. My nighthawk on AT&T has been largely underwhelming maxing out so far at 110-120 Mbit. My iPhone 6s routinely beats it -- ~140-150Mbit in the same location. No LAA on the Nighthawk in the US at least. I've not seen anyone post speeds faster than ~100-110 Mbit (in the US). Some Telstra videos I saw on Youtube show ~250-263Mbit via Ethernet connection to the M1. Unfortunately the firmware doesn't seem to indicate which bands are using CA. From the speeds, I doub't I've seen more than 2xCA here on AT&T.
