asolepascual's avatar
asolepascual
Nighthawk M1 or M2 extern supply
Can the Nighthawk M2 or M1 work without an inserted battery and as a fixed router? In other words, operate connected only to the power supply.
Thank you.
  • michaelkenward's avatar
    michaelkenward
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    The manual for the MR2100 says:
    Your mobile router can receive power from any of the following sources:
    • Rechargeable battery included with the mobile router
    • Wall socket using the AC adapter and USB cable
    • USB port on your computer
    I leave it to you to read the other manuals.
  • The M2 works without a battery for sure. But there were reviews that the complete 9V 1.67A power adapter is not sufficient for intensive LTE and Wi-Fi operation. I bought Xiaomi Mi ZMI USB-A 18W QC 3.0 Fast Charge EU (HA612 Black) 9V 2A, I use both a charger and a power supply without a battery. Three months have passed and no complaints. But perhaps in your case the complete adapter will be enough.
