helix919
Oct 09, 2017Guide
Nighthawk M1 Passthrough Mode + Ethernet
Hello,
What hope is a simple question, when enabling the IP Passthrough feature I understand it disables the Wi-Fi, but does it also disable the Ethernet port? I want to have the IP address assigned byt he Cellular Carrier tied directly to the Physical Ethernet port I have connected to the M1. Is this possiable?
Thanks,
- DarrenMSr. NETGEAR Moderator
This shouldn't disable the ethernet port is this happening for you?
DarrenM
