LorettaS's avatar
LorettaS
Follower
Feb 14, 2021
Nighthawk M1 password nothing works
cannot login on my iPad to the Netgear Nighthawk Mobile app. Will not accept the router password or "admin" that is suggested by system. It will not take anything I try to put in.
  • michaelkenward's avatar
    michaelkenward
    The M1 is actually the Netgear Model MR1100.
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Mobile Routers, Hotspots & Modems
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi LorettaS ,
    Have you tried entering the password you set on your M1 during the setup process?  If you open up a web browser from your iPad and browse to http://192.168.1.1, can you log in with your password?  Can you please post a screenshot of the mobile app version you are using?
    Arodi
