CPx
Aug 03, 2018Initiate
Nighthawk M1 public login - data offloading
Hi guys, Does anyone know if it's possible to use the Nighthawk's data offloading with a hotel's WiFi that requires a webpage login? I can't seem to find any instructions or guidence if this is ...
CPx
Aug 09, 2018Initiate
Found the solution myself and thought I should update this thread incase anyone else Congress across this.
Yes it is possible, connect to the open hotspot wifi signal via the data offloading page as expected. You may need to drop of WiFi connection (to the M1). On reconnection (may need the device rebooting or data offloading switching off and on), fire up a browser or if by phone enter the sign in page and continue as if you were connected directly to thebpublic hotspot
HTH
HTH
- bbdpegAug 20, 2018Aspirant
I received my Mobile Router today. I have been able to data offload using ehternet and my Comcast Business Class internet connection with ease. I will be traveling internationally next week and wonder if anyone has any experience trying to use a wired ethernet connection on a cruise ship. The goal is to share the ships internet with my devices while the ship is at sea and use my international data sim while in port. Like hotels, you must log in thru a ship logon screen to register the device. Any thoughts about making this work would be greatly appreciated. Most of the ships cabins have wifi as well as wired ethernet.
- Ninjaneer80Nov 12, 2018Aspirant
You shouldn't have any issues getting this to work on the ship using the method you mentioned
See page 30 in the manual
http://www.downloads.netgear.com/files/GDC/MR1100EE/MR1100EE_UM_EN.pdf
