gsmornot
Feb 21, 2018Aspirant
Nighthawk M1 Restarting and IP Passthrough
I have a AT&T Nighthawk M1 that will reset itself on a regular basis during use. Should I return it for another or is this something likely to be fixed by firmware? Restarts happen on battery or ...
JasonN
Feb 28, 2018NETGEAR Employee Retired
Hi gsmornot,
I wanted to check on you and see if your issue with your Nighthawk M1 restarting has been fixed.
Please let me know :]
- Jason N
gsmornot
Feb 28, 2018Aspirant
Yes and no. I found that a factory reset then only changing the admin passowrd and the SSID it would or has not reset. If I change the IP address range or change any other settings it will begin the resets. I wanted it to be on 192.168.4.1 but 1.1 will do for now.
My other M1 is waiting on a firmware update so I can use IP Passthrough. If I turn it on with the current firmware I get the "external" IP but cannot pass traffic. I can only pass traffic if I let the M1 assign a regular DHCP address. On this one I only use ethernet, the WiFi is turned off. Strangly it is setup for 192.168.5.1 but has been fine. It is indoors connected to 110V. The other is in the car connected to a 2.4A lighter adapter.
- JasonNFeb 28, 2018NETGEAR Employee Retired
Hi gsmornot,
Thank you for your response. I'm glad you have found a work around for this issue.
I will pass on the firmware update information for future reference. Thank you again :]
- Jason N
- gsmornotMar 02, 2018Aspirant
Had 3 resets yesterday so still need a fix. My Unite Explore is excellent but my Nighthawk is frustrating.
- JasonNMar 07, 2018NETGEAR Employee Retired
Hi gsmornot,
I'm sorry to see that it did not fix the issue. Can you please contact the NETGEAR support line for further assistance.
Thank you :]
- Jason N
