jtraz82
Apr 12, 2017Follower
Nighthawk M1 Static Routes
Hi there,
We are looking to roll out NightHawkM1's to a few of our sites as we want faster internet speeds.
However we need to setup static routes and I cannot find where to enter them in the GUI.
Please advise if this is possible and if so where to enter the Static Route settings.
Thanks,
James.
- DarrenMSr. NETGEAR Moderator
Hello jtraz82
I checked and it does not use static routes.
DarrenM
- dexxAspirant
Can the M1 operate as a true router? I have a client with a private APN with Telstra, so routing TO clients at a site, as well as from clients, is needed. Like many consumer grade "routers" the M1 (by default) nats its clients behind its own assigned WAN IP and doesnt actually route. Can it be set to do proper two way routing, including via its ethernet port?
