kdebauch
Mar 16, 2018Aspirant
Nighthawk M1 with Arlo Base Station
I recently recieved this hotspot router from AT&T. When they sold it to me they sent me a data sheet which said that it could be used as my Arlo base station. I have tried everything to figure out ho...
- Mar 27, 2018I updated the firmware and after a brief struggle, managed to get all of my cameras synced and working with the M1.
JasonN
Mar 16, 2018NETGEAR Employee Retired
Hi kdebauch,
I see that your M1 device is working properly because you have other wireless devices connected to it. I am going to move your post to the Arlo location of this community so you can have better assistance on your Arlo devices.
- Jason N
kdebauch
Jason, your response is false and completely opposite to the actual truth. My Arlo system works fine. The M1 is not allowing me to connect the Arlo to it. The ethernet port on the M1 does not recognize anything when connected. I have tried connecting it directly to my laptop, a 5 port unmanaged switch, as well as a router. None of these devices receieved any activity from the ethernet port on the M1.
- jguerdatMar 16, 2018Guru
Not sure Jason is going to see this. Since the Ethernet port seems to be dead, I would either swap it at an ATT store or contact Netgear support and open a case for replacement.
- kdebauchMar 16, 2018Aspirant
Do you think it is faulty? I wondered if that were the case, but AT&T told me that was normal for the port to not recognize any connections on the M1. I have never owned one before, so I have no way to confirm or deny this. Sucks that this got moved to the wrong section of the forum!
I woulda thunk the port would be active but anything is possible.
Repost in the appropriate forum and just leave the Arlo-specific part out or at least reference that any device, including Arlo, can't use the port.
