LRFloyd's avatar
LRFloyd
Nighthawk M1 working on T-mobile hotspot data plan?
I found a reseller of T-mobiles new data only plan that I believe will skip the professional install normally required. Seller say's incompatible with Nighthawk M1.. Why would that be?
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi LRFloyd
    Welcome to NETGEAR Community!
    MR1100 will work with T-Mobile as long as it uses the right data plan which is for Mobile Hotspot.
    Blanca
    Community Team
    • LRFloyd's avatar
      LRFloyd
      Is there any way you can point me to the plan that would work? can i post a link to an ebay seller?
