Paul-1930
Apr 18, 2017Follower
Nighthawk M1
The modem operates, but when, on my browser, I go to "192.168.1.1/index", the username is: 'admin', then enter the device password but the login fails. The message in red says 'admin' is incorrect. Apart from not knowing what it should be, it cannot be changed!!
Nighthawk M1 - MR1100 - Windows 10 - desktop computer- using only LAN cable connection to computer.
How can I fix this login issue?
1 Reply
- steveswNETGEAR Expert
The default admin password is 'admin'.
That should work unless you changed it during the initial setup.
If you can't remember what you changed it to, see p.75 of following doc for details on how to reset your default password:
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf?cid=wmt_netgear_organic
Steve
