EstherC
Dec 20, 2019Follower
Nighthawk M1
I cannot log in to update the router. Can you help! I must've changed the login password as admin doesn't work .
1 Reply
Login with what? Browser? App?
A reset is often the only way out.
There is support for the MR1100, including a manual, somewhere at the end of this link:
>>> MR1100 | Product | Support | NETGEAR <<<
By the way, it may not matter, but you have posted your message in the section of this community given over to Nighthawk WiFi Routers
R6000 Series AC WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message.
