Hondall-'s avatar
Hondall-
Follower
Jan 16, 2020
Nighthawk M1100
Can you leave the charger in all the time without damaging the battery?
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please advise the device SKU. You can find it under the battery.
    If you would like to use the device 7/24 with PA connected it, we suggest you to use the device without battery inersted. The device supports no battery operation. But there is a condition for doing. You have to use a Qiuck Charge PA with 1.8 or 2amp output.
    I need to know the SKU name to determine whether the your device was shipped with such PA.
    Thanks
