morganreed
Sep 27, 2017Follower
Nighthawk M1(MR1100) PS4
I am trying to set up my NightHawk M1 MR 1100 Mobile router to my playstation 4. I have tried wireless and Ethernet cable CAT 7 and only getting download speed apprx 10mbps and upload speed of 1 Mbp...
ArodiD
Nov 14, 2017NETGEAR Expert
Hi morganreed
I am not sure who your network provider is but the Telstra MR1100 on the Telstra Mobile network will never give you 1Gbps and Telstra also do not offer mobile data plans according to speeds you can get. The speeds you get from your MR1100 will depend on the mobile tower cloeset to you and will depend on a number of factory such as:
- Signal quality
- Amount of users also connected the same mobile tower
- If carrier aggregation is setup on the mobile tower
I am not sure how you are able to get 1Gbps with M1 connected to your PC. Are you able to share some screen captures, your network provider and your location and send it to adalpathadu@netgear.com as I am very interested to know where I can see 1Gbps speeds on a mobile network.
Kind Regards,
ArodiD
