PeterUK1
Feb 04, 2025Guide
Nighthawk M2 IP PassThrough stops working when idle
So I have a Nighthawk M2 in IP PassThrough with a VPN tunnel uplink over time it disconnects from 4G network for some reason and as soon as I login to the Nighthawk it springs to life. firmware NTG2...
rcpax
Feb 05, 2025Luminary
I would assume by spring to life, you mean it regains connectivity to the cell tower? Do you use it with a battery? Do you take it mobile or purely stationary connected to a wall charger?
There could be a few things going on here.
-o2 could be disconnecting you after being connected to their network for a while. ATT in the US seems to be doing this.
-if you are using a battery with your M2 and not taking it mobile, i would suggest using it on pure AC power using the charging brick and no battery. your device seems to be going into some sort of sleep mode, which is really not described in the manual. how is your VPN set up?
- PeterUK1Feb 05, 2025Guide
Thanks for the replies so far
Yes its always plugged in I don't see how removing the battery would help I have a VPN from Zyxel VPN300 that the Nighthawk is connected to which connects back to my virgin media Zyxel FLEX200 with pings going down the tunnel and I can see the tunnel drop I have tied a Connection Keeper app but does not come back to life until I login with password to Nighthawk then it starts working.
So its like this o2 gives out a 10. IP all works fine then 4G goes down Zyxel VPN300 picks up a IP of the LAN by Nighthawk I have set 192.168.7.0/24 I go to 192.168.7.1 login then it springs to life get 10. IP.
You might be right it might be o2 I was just hoping it might be a firmware bug.
So I have put the Nighthawk out of IP PassThrough mode and see what happens can take about 3 days uptime.
What I need is a app that can auto login to Nighthawk so that it stays up any ideas?
- PeterUK1Feb 11, 2025Guide
Well its been a week and no disconnects when out of IP PassThrough so its not o2 and must be a netgear when in IP PassThrough mode.
sadđ
- PeterUK1Feb 16, 2025Guide
Yup tried without the battery in IP PassThrough still disconnects from 4G after a number of days so Netgear has broken uptime for IP PassThrough.đ
- rcpaxFeb 16, 2025Luminary
so just to recap, the IP passthrough was working fine before the latest FW update happened? If that's the case, please submit a bug report for netgear may be able to address it in a future update
From what I can tell it was working fine with EE then moved EE to another Mobile Routers and o2 to the Nighthawk which get update in that time.
Problem is my technical support expired on 2024-09-02 and it not letting me do a submit a bug report for netgear
