PeterUK1
Feb 04, 2025Guide
Nighthawk M2 IP PassThrough stops working when idle
So I have a Nighthawk M2 in IP PassThrough with a VPN tunnel uplink over time it disconnects from 4G network for some reason and as soon as I login to the Nighthawk it springs to life. firmware NTG2...
PeterUK1
May 22, 2026Guide
Well I'm disappoint in Netgear not fixing this like they go to the trouble of adding IP PassThrough and fail to make it stable unlike my other 3rd party Mobile Router you can show and tell Netgear the problem but from what I can tell they just don't want people using IP PassThrough long term
