ccall48's avatar
ccall48
Tutor
Apr 06, 2019
Nighthawk M2 MR2100 (Advanced Settings Missing)
How do I access the advanced functions within the new M2 MR2100 device. The standard login does not give me access to setup 'advanced' options as described in the manual such as port forwarding etc.
I bought this device outright from a telstra store in australia.
  • Hi there can anyone including netgear tell me if the MR2100 has port forwding capabilities. If it does no seema to know how to access it??
    Cheers Bruce
    • ccall48's avatar
      ccall48
      Tutor
      I’m also still waiting.
      Contacted support and that didn’t help either.
      It’s a great device but without basic functionality control it’s just a paper weight for me.
      • a12b4c3's avatar
        a12b4c3
        It will be released in an upcoming firmware update - there were some issues with it previously.
