Tinsanta
Apr 23, 2019Aspirant
Nighthawk M2 (MR2100) constant reboot
Hi All, I just bought the nighthawk m2 and I am finding it really unstable. I am getting constant reboots when using the wifi function. The only way I have made it stable is by turning off wifi and...
- Jun 19, 2019
Hi All,
NETGEAR release MR1 Firmware NTGX24_10.13.05.00_00_TELSTRA_02.10_00 today which includes alot of bug fixes. Please upgrade your device to this latest firmware and let me know if the problem still persists. If you are still having issues after upgrading to the latest firmware then please send me a PM with the details.
ArodiD
Blanca_O
Apr 24, 2019NETGEAR Employee Retired
Hi Tinsanta
Welcome to NETGEAR Community!
Just to clarify, when you say "reboot", do you mean that the MR2100 turns off and on itself. May I request the following:
- Please describe your network setup
- How many devices are connected to the MR2100 when issue re-occur?
- Kindly access the MR2100 settings page and check if there is any firmware update available. What is the current firmware version?
I suggest to perform a factory reset as well.
Blanca
Community Team
angryface
Apr 25, 2019Aspirant
We are having the same problem.
We have checked the firmware there are no updates available. We have factory rebooted. We also have removed the battery and plugged it into the wall socket. We just removed the Netgear extender . We currently have 4 devices connected.
