Tinsanta's avatar
Tinsanta
Nighthawk M2 (MR2100) constant reboot
Hi All, I just bought the nighthawk m2 and I am finding it really unstable. I am getting constant reboots when using the wifi function. The only way I have made it stable is by turning off wifi and...
  • ArodiD's avatar
    ArodiD
    Jun 19, 2019
    Hi All,
    NETGEAR release MR1 Firmware NTGX24_10.13.05.00_00_TELSTRA_02.10_00 today which includes alot of bug fixes.  Please upgrade your device to this latest firmware and let me know if the problem still persists.  If you are still having issues after upgrading to the latest firmware then please send me a PM with the details.
    ArodiD
