Tinsanta
Apr 23, 2019Aspirant
Nighthawk M2 (MR2100) constant reboot
Hi All, I just bought the nighthawk m2 and I am finding it really unstable. I am getting constant reboots when using the wifi function. The only way I have made it stable is by turning off wifi and...
- Jun 19, 2019
Hi All,
NETGEAR release MR1 Firmware NTGX24_10.13.05.00_00_TELSTRA_02.10_00 today which includes alot of bug fixes. Please upgrade your device to this latest firmware and let me know if the problem still persists. If you are still having issues after upgrading to the latest firmware then please send me a PM with the details.
ArodiD
Mwmcgurk
Jun 15, 2019Aspirant
Hi Blanca
Just wondering if there is anything more to add to this thread? Had an M2 now for two day and has frozen (solid blue light and unresponsive) 3 times each day. Very frustrating as when it is running it is very good
Should I be returning it back to Telstra?
Thanks
Matt
Thanks
Matt
MikeMac-Au
Matt
Just a suggestion. In settings you can set the Nighthawk to NOT go to sleep. See if that works. Also unless you need battery take it out.
If you need a replacement chat with Telstra support, get escalated to a Case Manager who can then put an authority on your account to get a replacement. I have had my replacement now for 48 hours - touch wood no problems so far.
Cheers
- TinsantaJun 15, 2019Aspirant
I started this thread and ultimatly what worked for me was getting the unit replaced. Not much help in this thread on solving the issue, I just called the Netgear support team and they put me in touch with a special Night Gear support team member. I took them through the issues and what I had done to try and solve them. They stated that the unit was likely defective and put me across to the local support team to replace. They sent out a new unit and at the same time sent a courier for the old unit, so I was without internet for a day. Since then I have had no issues with the unit and the wifi aspect.
Good luck!
- HSvaneAug 22, 2019Aspirant
Where in the settings can I set it to not go asleep?
I have look but cannont find it. Have also looked in the manual with out luck.
Regards
Henning
- SvenPAug 22, 2019Guide
Open a browser in a PC - and write http://m.home and hit enter
Take a look on your Quick Start instructions you received in the box.
Go to Set up the device and item 2 and follow instructions.
You can not change ETHERNET STANDBY option in the mobile ap.
The Ethernet standby regulate the time for asleep.
Henning
HSvane wrote:Where in the settings can I set it to not go asleep?
Regards
Henning
are you Swedish?
See attached file for disable unit to go to sleep.
Hi Sven
Thanks that helps.
No I am Danish.
Regards
Henning
