Söldier
Nov 05, 2019Aspirant
Nighthawk M2 MR2100 speed reduction
Hello,
after using the M2 for a few days, it appears that the speed is significantly reduced.
At the original set up i get speeds of 100MBps+.
Then after a few days use (ethernet out to wifi router always on), the speeds drop to under 60MBps.
When I notice the reduction in speed, a reboot does restore the high speeds - but then within about 2 hours, the speeds drop again. Reboot again and the cycle continues.
What's more is that I was able to get faster speeds sustained for longer after doing a factory restore - then, again, I get about 2-4 days of good speeds. At this point rebooting behaves the same as above.
Is there any more troubleshooting steps I can take to investigate why this is happening?
Its almost as if CA is dropping off.
My configuration is quite simple, only changing two settings,
1. IP passthrough on
2. Ethernet standby off
Battery is remvoed due to it being on all the time.
Temperature ranges between 37°C and 49°C
Thanks
- SöldierAspirant
Also, forgot to mention, the band is always on Band 3
- n3tApprentice
You have some other WiFi router connected to the Ethernet port of your M2, do I understand this correctly? (If I don't please elaborate.)
How are you checking the speed? With some app running on a computer, phone or tablet connected to this other router over WiFi?
In my case I found that this other router was the culprit which had to be rebooted to restore the original speed for devices connected over WiFi; the speed of the Ethernet ports of the router did not degrade FWIW. (My case does not involve an M2 though.)
