Chainsawkid
Aug 14, 2020Aspirant
Nighthawk M2 wifi not working
Hi. My M2 wifi just stopped working. It has an X through the wifi icon. I didn’t change any settings. I have factory reset it and still not working. I can’t connect it to my computer as I don’t hav...
Chainsawkid
Aug 16, 2020Aspirant
Nope. It’s all on and factory reset. But I get an x through the wifi icon
Bcanr2d2
Aug 19, 2020Aspirant
I have the same issue, with the most recent firmware update appearing to cause the issue
Firmware version NTGX24_10.17.03.00
I've tried to enable and disable IP Passthrough, as well as enable and disable USB tethering, to force the device to enable the wifi again, but like you I have factory reset to no avail, as the wifi appears to be disabled.
Is there a CLI to change a erroneous setting to get this unit working properly again?
