Stingraye's avatar
Stingraye
Nighthawk M2
Hello community is there any way to improve recpetion in a weak signal area ? antenna.
  • michaelkenward's avatar
    michaelkenward
    Are you asking about the M2 or the AC2100 in your footer?
    If the former you might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Mobile Routers, Hotspots & Modems
    • Stingraye's avatar
      Stingraye
         Sorry my mistake I did not scroll all the way down.
             Ray
