IR99
May 20, 2026Initiate
Nighthawk M3 MH3150 and Ethernet Adapter - USB-C input does not charge battery
I have a Nighthawk M3 MH3150 and a Netgear Ethernet adapter.
(The M3 has no ethernet port, just a USB-C one, so needs the adapter for ethernet).
The adapter has one 'in' port USB-C to connect to the M3, one 'in' port for USB-C power-in, and one 'out' port for ethernet.
When I plug in the adapter, ethernet works fine.
BUT the 'in' port for USB-C power-in does not keep the M3 charged.
The lightning charging on the M3 battery icon does not appear.
I have tried many, many different USB-C power sources from 10W to 60W and still no charging.
Does anyone use this setup?
Is there some obscure config setting I need to change somewhere to get this battery charging active?
1 Reply
Using the original Netgear power supply delivered with your Netgear M3?
The "original" Netgear https://www.netgear.com/mobile-wifi/hotspots/usb2eth/ adapter?
