Mr_Khalid
Apr 12, 2022Star
Nighthawk M5 MR5100-1Z1MES useless In Middle East
Good day NETGEAR COMMUNITY ! ,
First of all, We are in big trouble because a lot of people In Middle East They didn't get the new update :
Model: MR5100-1Z1MES
Firmware Version :
NTGX55_12.04.12.01
GUI Version:
MR5100-1Z1MES_04.02.197.00
HW Version: 1.1
_________________________________________________________________
Most of people stuck on version :
10.12.13.0
10.28.02.00
Which is very old version and you cannot change band option's from the router ! You shall to change It from 192.168.1.1 !
Also, when you tried to check for updates It's give you UP TO DATE !
Is it difficult for a large and leading company in the field of routers like Netgear to Push an OTA update 12.04.12.01 to all owners of the MR5100-1Z1MES model ?
By the way .... The vendor not cooperate at all In Middle East
Firmware Version :
NTGX55_12.04.12.01
GUI Version:
HW Version: 1.1
10.12.13.0
10.28.02.00
- UPDATE:
After contact with Zain KW, and give them the router, they finally update It to latest firmware!
Thanks to all ..
UPDATE 2:
Many of routers on Zain KW got the new FW update today !!!! No need to send It to Zain !!!
- sult4nInitiateI have the same problem with the same router, the (check the attached image), the seller is not cooperating. if the support could help us with a link to the latest version so we can upload the update manually, or push the update over OTA to all MR5100-1Z1MES users, we really need help to get the latest enhanced firmware ;(
- S3llawiInitiateI do have same issue
- mamryInitiateI also got stuck with this very old firmware version 10.12.13.00, It’s huge disappointment..
Still hoping Netgear will fix this issue.. - Mr5100vInitiate
I have the same issue. My device has an old firmware version and it can not find the latest firmware via OTA.
- Ksa3344ApprenticeHey Netgear
Thank you for this great device .
Could you please reach out with Zain vendor in Meddle East to speed up pushing the update to all or at least provide the update file here so we could update it manually .
its been 5 months since the update is released and still lot of ppl didn't get it yet . - i hope fix this problem
- DinarsInitiateAlso, I did not receive the update, although there are others who have an update, which is what differentiates the treatment of your customers And there may be no doubt that this is racist behavior in some countries in the treatment of customers
- Nasser1993InitiateI am also having the same issue, i hope NERGEAR will solve this soon.
- KeepINtouchInitiateI have the same issue, hopefully Netgear support centre fix it as soon as possible.
- 2pedInitiateme too i have the same issue, unfortunately no update has been pushed regionally,
hopefully Netgear can push an update across all MR5100 Routers
