Mr_Khalid
Apr 12, 2022Star
Nighthawk M5 MR5100-1Z1MES useless In Middle East
Good day NETGEAR COMMUNITY ! ,        First of all, We are in big trouble because a lot of people In Middle East They didn't get the new update :        Model: MR5100-1Z1MES        Firmware Version : ...
- Apr 18, 2022UPDATE:
After contact with Zain KW, and give them the router, they finally update It to latest firmware!
Thanks to all ..
UPDATE 2:
Many of routers on Zain KW got the new FW update today !!!! No need to send It to Zain !!!
Blanca_O
Apr 12, 2022NETGEAR Employee Retired
Hi, All,
Welcome to NETGEAR Community!
Let me check on this. We will provide update once new information will be available.
Can you also describe the issue you are facing with the current firmware?
Blanca
Community Team
- Mr_KhalidApr 12, 2022Star
Hi Blanca_O ! ,
Thank you for response.
By the way, I have 2 Routers of MR5100-1Z1MES1, old and new firmware.
For firmware 10.12.13.0 & 10.28.02.00 there's many Issues :
1- You cannot change band region from the router screen, you shall to navigate to 192.168.1.1 or Netgear app to change It !
2- Unstable of speed , ping , jitter, RSRP, RSRQ, SINR.
3- Switch connect from LTE+ to 5G always every couple of minutes.
4- The carrier name replaced from your ISP to unknow. EX: Zain to unknow.
5- There's some very important AT! Command It's gave you error ! Like: AT!BAND=04,"1800",0,4 It's give you error sometimes.
With the new firmware 12.04.12.01 :
1- You can change band region from the router screen !
2- Stable of speed , ping , jitter, RSRP, RSRQ, SINR.
3- Stable connection of 5G and It's not switch to LTE+ like old firmware.
4- The carrier name correct always.
5- AT! Command Works fine without any error ! So, you can add band frequency without any Issue.
 - KeepINtouchApr 12, 2022InitiateHi Blanca , thanks for responding , as we all know the main goal from the updates are to fix bugs , mail function, unstablity and to enhance the frimware , In our case we stocked in old version of frimware mean while others were able to get the latest frimware , đ§ I am wondering whoâs responsible? Kuwait Zain telecom or Netgear ? Am sure day after day you will see many Netgear mr5100 Zain version users will complain about this issue in Netgear Community , In four words ( We Deserve Best Service) , Thanks
