Mr_Khalid
Apr 12, 2022Star
Nighthawk M5 MR5100-1Z1MES useless In Middle East
Good day NETGEAR COMMUNITY ! , First of all, We are in big trouble because a lot of people In Middle East They didn't get the new update : Model: MR5100-1Z1MES Firmware Version : ...
- Apr 18, 2022UPDATE:
After contact with Zain KW, and give them the router, they finally update It to latest firmware!
Thanks to all ..
UPDATE 2:
Many of routers on Zain KW got the new FW update today !!!! No need to send It to Zain !!!
Nour2022
Apr 13, 2022Initiate
I have the same problem with M5 5100 from Zain, the update 10.28.02.00
- DinarsApr 13, 2022InitiateIt is the same problem that Mr. Khaled explained
Unstable of speed , ping , jitter, RSRP, RSRQ, SINR.
I hope this problem is fixed by sending an update to our devices- Blanca_OApr 13, 2022NETGEAR Employee Retired
Hi, All,
I got an update from the product team. There are two different FWs for MR5100-1Z1MES units. The FW v10.x.x.x is the latest FW for MR5100 units with 4GB of memory. And the customer with 8GB of memory MR5100 can only update to FW v12.04.12.01.
As for the issues with the FW 10.x.x.x, kindly report those issues to Zain.
Blanca
Community Team
