stephenlatty
Mar 24, 2023Follower
Nighthawk M6 5G WiFi 6 Mobile Router Turn Specific Channels On/Off
Is it possible to turn specific channels off across the 5G band on this device? Or am I limited to turning the 5G or 2.4G on or off as a whole?
If you use the netgear mobile app you can go in through wifi settings and change the channels.
Just tested it to ensure on my MR6110
NETGEAR Mobile App | NETGEAR Support
- JohnPengNETGEAR Expert
Yes. You can manually set which WiFi channel to use on 5G or 2.4G. But you can only set the device to use one certain channel.
Thanks
John
