wardh_2021's avatar
wardh_2021
Follower
Sep 11, 2024
Nighthawk M6 invalid SIm
Hi,
I got a Netgear Nighthawk M6 from Optus and I changed the wifi offloading setting then I changed back to the original setting. I also enabled the Ethernet port as well.
Problem is now it comes up with an invalid SIM error.
How should I fix it? Is a factory reset safe?
Plus why would making some settings changes like this invalidate the sim?
Thanks
Ward
No RepliesBe the first to reply
