ADOOL's avatar
ADOOL
Tutor
Aug 05, 2023
Nighthawk M6 mr6110-1s4mes Doesn`t work on 5G N78 frequency on STC Saudi Arabia‏
Hello, I have a Nighthawk M6 device, model mr6110-1s4mes, version NTGX65_12.01.16.00, but unfortunately it does not work with 5G on STC n78. I hope to find a solution to this problem, noting that I noticed that the problem is only with this company. I have another company that uses the n78 frequency and Frequency works on the device
  • We are in the process to release the MR to address the issue. Expected to be released in the next couple of weeks.
    Please standby.
    Thanks
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please standby.
    Thanks
      • mcuadrado's avatar
        mcuadrado
        Guide
        Can you contact me privately , i will try to help with the new release .
        Regards!
