StuartCRyan
Mar 11, 2023Tutor
Nighthawk M6 Pro Connection Issues and Power Issues
Hi All, I have a Nighthawk M6 Pro (Telstra, Australia). I am having a couple of problems and I am wondering if anyone has any experience or thoughts: Connection can be flaky, sometimes connects (h...
Mar 12, 2023Guru - Experienced User
Really sounds like your power adapter isn't putting out the power it needs. I have the MR6110 and it works/boots great without the battery. But only if I'm giving it enough power. Some of my powerbanks won't power it at all. That's what I'd start with checking
StuartCRyan
Mar 13, 2023Tutor
Thank you! Seems like this might be a known issue with my firmware edition. Hoping I can get a beta version!
- igorjrrMar 14, 2023Apprentice
This keeps confirming how M6 Pro is an unfinished product full of bugs. If you can, return it for a full refund.
