masterbeat
Nov 15, 2022Star
Nighthawk M6 Pro Constantly Locking Up, Screen Freezing, Dropping Internet
I have a new M6 just 2 days old, will be running fine, and then at various times (no rhyme or reason), can be up for hours, or 5 minutes, the screen looks up, won't respond, drops internet completely and pushing the power button will get the screen to flash on and off once in a while.
I've been using it plugged in WITH the battery inside as well. The only way to restart it is to physically pull out the battery and remove power, then start back up again.
Then 5 minutes to 5 hours later it does it again.
I'm seeing other topics about "overheating" issues, but it never feels hot at all. Is what I'm experiencing "the overheating" issue or something else?
Not impressed with this $800 router Netgear... need the fix shared immediately or we're returning it, as I'm on a road trip this was purchased for and need it to work NOW, not in weeks. Please advise how much longer to push the update or if I need to just return it and get a hotspot that works.
- Rdt14AspirantI have literally been dealing with the EXACT same issue. I have had my m6 pro for 3 months, and it seems to get worse and more frequent. I have tried calling netgear with no conclusion, did not have a good customer service experience. I also run my m6 pro with a netgear router in AP mode. I have tried running it with battery and without battery. Im at the point to where im wanting to pay for internet that is twice as expensive in my area, just so i dont have interruptions like this. For being such an expensive item it makes me to want to NEVER buy another Netgear product. If they dont release a fix for this in the coming month i will sell it. Best of luck to you. Netgear really needs to get their stuff together. These issues have been going on since release.
- Harvey1010AspirantSame exact issue here
- Harvey1010AspirantMine is laggy, freezes up, and disconnects from mobile broadband service, no explanation
- NWFotoAspirantMine does the exact same. Have you found a solution?
Yes, John Peng at Netgear pushed a beta firmware update to me that solved everything. It's my understanding that firmware is now available to everyone, have you checked for a firmware update?
- NWFotoAspirantI updated to the new firmware this morning after sending my reply. But now the thing won’t connect to att.
