AnnetteL
Sep 06, 2025Star
Nighthawk M6 Pro Ethernet port
After recent automatic update, Ethernet port on nighthawk M6 Pro not working. Can toggle it on/off, but has no output signal. Any troubleshooting suggestions?
Joenemba
Sep 06, 2025Guide
Oh shoot, was just coming to report this exact issue. For me, the Ethernet port works for a span of like 2-7 minutes after restarting my router or computer, then it just suddenly is unable to identify the network. Nothing I've done has helped.
AnnetteL
Sep 06, 2025Star
Yes, ours will stay up for 30 sec to 2-3 min before disconnecting. No amount of rebooting, turning/off Ethernet port makes a difference.
- JoenembaSep 06, 2025Guide
It's so strange. I've tried a factory reset to no avail, I've refreshed it's connection with AT&T from the website. My only idea would be to maybe... set a static IP, see if that works?
