AnnetteL
Sep 06, 2025Star
Nighthawk M6 Pro Ethernet port
After recent automatic update, Ethernet port on nighthawk M6 Pro not working. Can toggle it on/off, but has no output signal. Any troubleshooting suggestions?
AnnetteL
Sep 06, 2025Star
Yes, ours will stay up for 30 sec to 2-3 min before disconnecting. No amount of rebooting, turning/off Ethernet port makes a difference.
Joenemba
Sep 06, 2025Guide
It's so strange. I've tried a factory reset to no avail, I've refreshed it's connection with AT&T from the website. My only idea would be to maybe... set a static IP, see if that works?
