AnnetteL
Sep 06, 2025Star
Nighthawk M6 Pro Ethernet port
After recent automatic update, Ethernet port on nighthawk M6 Pro not working. Can toggle it on/off, but has no output signal. Any troubleshooting suggestions?
ntweather
Sep 07, 2025Tutor
Same problem, ATT just wants to send me a new router but feel will have the same problem. Anyone been able to downgrade firmware.
- WesCSep 09, 2025Tutor
I have multiple ones doing the same thing. I can't even get through to ATT's tech support. I believe the only fix is going to be to another firmware.
